Faster Battery Drain after Started Using Modes & Routines.
(Topic created on: 02-16-2024 02:41 PM)
GALAXYECOSYSTEM
Hello Members!
Currently I am using my S24 Ultra. Just recently I started using the modes & Routines for my convenience and I realised that only after then the battery is draining faster. Because since the purchase and before using Routines I didn't face any battery drain issue.
For e.g. in normal night earlier my phone used to drain hardly 4 to 5%. But yesterday when I put it on Night Routine, the drains was around 15%.
Anybody here who have experienced battery drain issue after using "Modes & Routines" please share your valuable input.
Update/Resolution - The Google message app was eating the battery even though I wasn't using. Found out that through my interaction with a Samsung Executive. Disabled that app and since then didn't face any issues of battery drain.
"So it was not the Modes & Routines rather Google Message app being the reason behind my faster Battery drain".
Time to disable all the unnecessary preinstalled Google apps for which we have a Samsung alternative such as message, call, files, photos etc. from our Samung devices.
17 Comments
Darkvader12
Expert Level 3
no I am not facing it at all
Are you using Routines? Like if you have any suggestions for me to improve my battery health.
Darkvader12
Expert Level 3
Wait I give you some tips
Darkvader12
Expert Level 3
Darkvader12
Expert Level 3
prajwalmali
Please tell me in 1st image why lock screen shortcuts are off ?
Darkvader12
Expert Level 3
Ah these I don't want people to make unauthorised usage of lock screen shortcuts unlike apple which on limits the camera and torch I forgot that android had the option to turn off the shortcut I dint noticed it first thanks I used s9 and later I used iphone 12 pro for 4 years so I just forgot that android had the option to turn of the shortcuts permanently
And well thanks for pointing it out
I really forgot that there was option I thought the android does not had this option I thought android don't have the option so made it in the routines
Well thanks for pointing out I will remove this condition
prajwalmali
Yup that's what I thought too that we can remove those shortcuts. Good to know people take privacy and security seriously.
Darkvader12
Expert Level 3
