Fast battery draining issue in new s21 ultra
(Topic created on: 01-27-2024 09:22 PM)
karan08
Hi, 2 month back I purchased new Galaxy S21 ultra, and I have noticed the battery drains pretty fast. In the normal use its always empty before the day ends. I also did the all battery saving settings in phone but I am still facing the problem.I compared with other Samsung S22 ultra and S23 ultra. My New S21 ultra battery drained super fast as compared to S22 ultra and S23 Ultra. Also I have checked battery health but its showing good. Pls suggest.
4 Comments
iamrohitkm
There's nothing like that on my 2 yr old s21 ultra.
cs_member10
Dear Samsung Member,
however, we are taking your valuable feedback regarding this.
Battery life depends on how the battery is used. Note that different devices have different battery life. The expected battery life for your model can be found in the manual.
We would like to inform you about the standard charging procedure (charge in one go instead of charging many times as it affects the life span of the battery and battery performance).
Charge in one go instead of charging many times as it affects the life span of the battery and battery performance.
Perform Battery Optimization.
Settings > Select Device Maintenance/Device Care/Battery and device care > Optimize > Optimize all options like Battery, Storage, and Memory.
Turn off Wi-Fi, GPS, Bluetooth, etc.
Turn off unused functions like Wi-Fi, GPS, Bluetooth, and location settings when not using them: On the home screen swipe down the notification panel > Turn off Wi-Fi, GPS, Bluetooth, and other connectivity features when not using them.
Check device network fluctuation
Kindly check whether the mobile network fluctuates frequently or if the network signal is low in your area. In both cases, the battery will drain considerably fast.
Recommendation: We recommend you avoid using it in areas with low network/fluctuation.
Reduce display brightness level.
Kindly set the device display brightness in auto mode (If available).
Adjust screen timeout settings: Settings > Display > Screen timeout > Select minimum screen timeout.
Check and update the App: Kindly check which application or interface is using more battery from device care. And try to update the app or avoid using that app.
Close background running apps.
Close all the background running apps when not using them,
Turn off auto sync of e-mails, app data, etc.
We request you turn off the auto sync option, it will stop the synchronization of the device with the server & reduce the battery drainage.
The steps to turn off auto sync are:
2. Turn off the auto sync option.
Check your device in safe mode: https://www.samsung.com/in/support/mobile-devices/safe-mode-on-samsung-phones/
Reset your device: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-mobile-how-to-perform-a-factory-res...
In case the issue still occurs, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
anilshin
Don't change phone every time 100% charge 85% change the battery
karan08
Dear sumsung support team,
Thanks for your suggestions, I already tried all the above-mentioned methods, but I didn't get any results. Also, I am an old samsung customer I know about battery life.
It's my new phone. It's hardly 2 months back I purchased. In full charge its showing 13 hours only.
