battery drain on S22 Ultra
(Topic created on: 2 weeks ago)
Raju001
I have updated to #OneUi7 on #S22ultra. But now battery is draining too fast. Can anyone please provide a solution for this ?
5 Comments
kalp0122
When you started to use your mobile when you bought it learns your pattern of usage and adapts to it, so it will take a week for the system to adapt, or else you can disable the adaptive battery option in the battery settings.
Raju001
Got it. But i have been using this phone since 1.5 yrs. Battery is draining fast compared to previous os version.
kalp0122
You mean, the update was 1.5 years before? Or May be try this link
https://youtu.be/qGH7FlmOErI?si=01reJkL-65S1z9ZT
Raju001
Thank you.. 🙂❤️
cs_member10
Dear Samsung member,
9. Reset the device:
IMPORTANT:
• For this:
