S23 ultra Battery drain - 2nd May Security patch
(Topic created on: Sunday)
Abubackerrazak
 Has anyone received may security patch 2nd time?
I received only once
2nd may security patch is solving battery drain problem to some extend for s24 ultra users.. one of my friend is getting 6 to 7 hours SOT
If any has received please reply
10 Comments
I did a factory reset after waiting for almost a month for samsung to provide a fix. The situation is a lot better now for my device.
Pls Share screenshot of your SOT and battery usage by apps
I did this reset yesterday. So battery is in learning usage pattern mode. But I got around 4 hours SOT on my s23 with 79 percent battery.1749368888565.jpg
And the phone is not heating that much.
3 to 4 sot Hours is very less brother
Mine is s23 and not ultra...also 4 hours is on 79 percent. It will give around 5 on full charge which is fine for s23 base model.
NOMAĐ
Getting 4 hrs on 50% usage.
I did a factory reset as well. Initially in Learning phase, battery life is bad.
Now out of blue, i got this sot yesterday. Literally not sure what happened.1749435145241.jpg1749435491365.jpg
This is great.. did u receive any security patch update?
NOMAĐ
No. I waited till may patch for fixes. But no fixes provided by samsung. So did a factory reset.
Even after factory reset, it nearly took 10 days to get this result.
