Facing heating issue on my device S9 Plus
(Topic created on: 06-19-2025 03:12 PM)
Lokesh2908
Team, kindly support me to resolve my query for heating. My device heats a lot last few days.
6 Comments
jay280
Battery might be too old making phone heat up check battery health
goodthings
Your's most welcome to here.
Lokesh2908
My device running on Android 10....I think team will not release any software for this
goodthings
Kindly reset factory data with backup then try to It's again. If you like Please accept as a solution it's help to other users also, click on 3dots in my reply section and click on accept solution. Thanks.
cs_member10
Dear Samsung Member,
1. Turn off Wi-Fi, GPS, Bluetooth, and other connectivity features when not using them.
2. Decrease the screen brightness.
3. Close background running apps.
4. Uninstall the unnecessary apps.
5. Reduce long duration of graphics intensive gaming sessions as it may cause heating issue.
6. Avoid usage of mobile phone when charging.
7. Update software: Go to Settings > Software update > Download and install > Checking for software update > Software update available > Tap on Download > Downloading updates > Tap on Install now.
8. If the issue is still not been resolved, Reset the device:
IMPORTANT:
• For this:
• Open Gmail (https://accounts.google.com/servicelogin) > forgot password >Select ""try another way"" > Next > Enter a new password > Next.
Settings > General Management > Reset > Temporary cloud backup or External storage backup > tap on Factory data reset (This will erase all data, including files and downloaded apps)
If the issue still persists, after performing all troubleshooting steps, would request you to please visit the service center. Below is the link to find nearest service center
http://www.samsung.com/in/support/servicelocation/
JithinAjith
Expert Level 3
Update Google Play Services
Update all apps
