Heating and fast Battery drainage
(Topic created on: 10-16-2025 11:36 PM)
MdHasan01
Hello, Dear Developers,
I am writing to inform you that I am using the S24 FE device. I have recently updated it to Android 16 / One UI 8. All the features are working fabulously without any lag; however, I am facing moderate heating issues and fast battery drainage.
Another minor requirement for Samsung devices is a real-time data speed meter. Since the device does not include such a system feature, we are forced to rely on third-party applications, which indirectly compromises Knox security. I hope Samsung will respond positively and address these issues and needs in the upcoming updates. Thank you.
11 Comments
YOUR_EX
Dear, maybe it can be issue happening due to software bug, wait for some time it will solve, if it not solved kindly please complaint to the samsung customer support team or samsung service center through the WhatsApp or call I hope they will fix your issues soon.
If u find this is helpful Click on the three dots of my replies right corner nd accept the solution 😊
timkamat
Don't blabber if you don't know the things.
Battery drain is common after a major update. If it does not get back on track in a week, you can contact the service centre
YOUR_EX
And what did I say then?
timkamat
You said software bug... It's not a bug, or glitch. It's part of normal optimisation. If you want to sound technical, please use the right terms. Bug is an issue and this isn't.
YOUR_EX
I said "maybe"
cs_member10
Dear Samsung member,
Please perform the below-mentioned troubleshooting steps, these may help in resolving your concerns. We are taking your feedback and will take it into consideration for future updates.
▶ Galaxy device Battery drainage issue: Charge in one go instead of charging many times as it affects the life span of battery and battery performance.
2. Check device network fluctuation.
3. Adjust screen timeout settings: Go to Settings > Display > Screen timeout > Select the minimum screen timeout.
4. Check which application is or interface is using more battery from device care and try to update app or avoid using that app.
6. Turn off auto sync of e-mails, app data etc.
▶ Galaxy device heating issue: 1.Turn off Wi-Fi, GPS, Bluetooth, and other connectivity features when not using them.
2. Decrease the screen brightness.
3. Close background running apps.
4. Uninstall the unnecessary apps.
5. Reduce long duration of graphics intensive gaming sessions as it may cause heating issue.
6. Avoid usage of mobile phone when charging.
7. Update software: Go to Settings > Software update > Download and install > Check for software update > If Software update available > Download > Downloading updates > Install now
8. Reset the device:
IMPORTANT:
• For this:
Please follow the below steps to reset the device: Settings > General Management > Reset > Temporary cloud backup or External storage backup > tap on Factory data reset (This will erase all data, including files and downloaded apps)
If the issue still persists, after performing all troubleshooting steps, would request you to please visit the service center. Below is the link to find nearest service center
http://www.samsung.com/in/support/servicelocation/
surajss
I went to service center thwy are telling its normal but its hell to use this phone with heating rhat also in winter.
goodthings
surajss
