Resolved! Solved
Edge Lighting issue in S10+
(Topic created on: 04-03-2021 10:49 AM)
HBCDOHA
Did anyone have edge Lighting issue after update One UI 3.0 in S10+
8 Solutions
PsychoBOT
Yes I have Edge light issue after upadte One UI 3.0
PsychoBOT
Try to steps to enter safe mode.
PsychoBOT
Method 1:
1. Power off the device.
2. Press and hold the Power key for one or two seconds to turn on the device.
3. When the Samsung logo appears, press and hold the Volume down key.
PsychoBOT
Exit safe mode:
1. Press volume down and power key simultaneously for 5 seconds to restart the device.
2. Press the power key on the right hand side and tap on the restart icon on the screen.
3. Swipe down the notification panel to access it. Select the notification safe mode enabled and tap on off to restart the device.
PsychoBOT
Try to reset your all default settings
PsychoBOT
Restart the phone and check again
PsychoBOT
One last try Factory reset and check it's working or not
PsychoBOT
18 Comments
PsychoBOT
PsychoBOT
PsychoBOT
Method 1:
PsychoBOT
Exit safe mode:
HBCDOHA
Try all this but no use as the same now
PsychoBOT
have you checked your device in safe mode?
HBCDOHA
Yes it's off now
PsychoBOT
Is your device working properly now?
HBCDOHA
No same
