Resolved! Solved
Edge Lighting issue in S10+
(Topic created on: 04-03-2021 10:49 AM)
HBCDOHA
Did anyone have edge Lighting issue after update One UI 3.0 in S10+
Resolved!
18 Comments
PsychoBOT
Try to reset your all default settings
PsychoBOT
Restart the phone and check again
HBCDOHA
No way its all the same as the first 😪
HBCDOHA
Done that and try to restart I'll tell you after this
PsychoBOT
One last try Factory reset and check it's working or not
HBCDOHA
Thanks man it's working now
PsychoBOT
Samsung_specialist
Yay!
adhamdarwish
You mean the side lighting when you get notifications
