Edge lighting style notification
(Topic created on: 10-10-2024 02:34 AM)
Glitch88
Beginner Level 3
Noticing the edge light style notification stop working after the latest update..
Anyone having the same issue as me ????
3 Comments
OwnPersonality
Hi
Edge lighting style notifications works normal with the latest update.
Did you check the setting itself?
I found that the lighting nofitications got disabled once beofre after an update.
Glitch88
Beginner Level 3
Hi
It is not disabled
I checked it many times
I don't know what wrong with it
I really like this feature
It makes me sad that it is not working right now
Samsung_specialist
If the problem persists after trying to enable the feature, please send us an Error Report by following the steps below:
1. Head to the Members app.
2. Select Get Help > Error Report.
3. Tap 'OK' to send System Log Data.
4. Choose the symptom and include as much detail as possible.
To ensure that your logs accurately reflect the issue you're experiencing, please submit your report within 5 minutes of encountering the problem. Our engineers will then investigate and provide you with a solution via the Members app.
