12-05-2024 05:17 PM in
Galaxy S- Mark as New
12-05-2024 05:46 PM (Last edited 12-05-2024 05:47 PM ) in
12-05-2024 05:49 PM in
12-05-2024 05:56 PM in
Galaxy SThen go down to charging settings...
From here u can turn it off
12-05-2024 06:10 PM in
Galaxy SIf this reply answered your query please mark my reply as "resolved" by clicking 3 vertical dots on top right of my reply. Thank you 😊
12-05-2024 07:17 PM in
Galaxy SAm also considering the suggestion Sobin78 gave but 45w brick is little expensive
12-05-2024 07:31 PM in
12-06-2024 09:21 AM in
Galaxy SDear Samsung Member,
As per your query, we want to inform you that the 15W charger is simply a programmable power supply, there is no issue with does not affects battery of s24 ultra. When you use the 25/35 watt charging adpator with your device it will take less time to fully charger as compare the 15 watt charger.
However, It’s also important to note that even when you’re using chargers rated at 25W or 15W, the actual wattage delivered to the battery reduces as it reaches higher levels of charge. This feature is built-in to protect the health and longevity of the battery, ensuring that you get the most out of your device over time.
