A user's guide to resolve Galaxy S22 Battery and Heating issues
(Topic created on: 04-20-2023 06:33 PM)
ashwaneee
Hello Friends I'm seeing that most of us are facing Low Battery and Heating issues on our phone. So here I'm sharing my experience with you all by which I'm getting around 4.5 - 5 Hrs of SOT on My Galaxy S22 and noticeably low heating.
1. Regularly restart your phone at set time.
2. Regularly clear recent apps.
3. Put unused or rarely used apps to deepsleep.
4. Browse Facebook and Instagram from the browser itself, as both of these apps consume alot of battery and data.
5. Start using data saver as it cuts down on background data syncing activity. You can only allow some of the necessary apps to use data like whatsapp, email and truecaller.
6. Stop using always on display as most of us always keep are phone in our pocket or in hand, so no sense of using AOD.
7. Use dark black wallpaper as well as dark mode on your phone.
8. Also I have noticed that whenever I put my phone on 5G, my phone starts heating and Ram usage also increases. Network also fluctuates between 4G and 5G, that affects battery.
9. When you're in low network area, avoid using data connection as mobile consumes more battery searching for network.
10. Charge your phone from 15% to 85% in one shot, so that battery can adjust itself according to your usage patterns.
11. Use only Samsung's original adopter and cable to charge your phone.
12. If you regularly watch movies or videos on your phone, use a mobile stand for it as sometime device gets hot due to our body temperature.
13. Install only important apps which you use on daily basis.
14. Also you can disable some of the built-in apps from Google and Samsung.
15. If you're not a heavy user then don't use back cover on your phone as it restricts phone from releasing heat.
16. You can customise your phone by using good quality skin wraps, they also prevent your phone from getting daily routine scratches.
17. Don't use your phone while charging.
18. Stop all the annoying notifications.
19. Switch off GPS, Bluetooth and Mobile data when not in use.
20. Use adaptive brightness feature.
Friends the points which I have shared above are according to my usage patterns.
Other user's reviews are also welcome.
All in all Galaxy S22 is a very powerful device, I know there are some problems but considering it's size and beauty, we should avoid that.
#Samsung #Galaxy #S22 #Battery #Heating
#Tips
10 Comments
Well done brother 👏 👍
Faisal01
So in one line your are saying that toh compromise ecery thing after buying a flagship device
ashwaneee
Why to compromise on every thing. Considering the usage patterns of the customers, Company has launched 3 different models for the same device.
Faisal01
Bro we have to agree that one ui is heavy ui with many features so battery usage is high they shout fic baterry drain issue in their flagships i have s21 fe on 120 hz in mostly give 4 hrs or less with no 5g
ashwaneee
Yesss that's true and samsung apps are also high power consuming.
Faisal01
The points you have mentions some are baseless like Aod in pocket when you put you phone in pocket or put something on camera and light senson the aod gets turn off automatically
ashwaneee
The meaning behind that topic is when the phone is in your reach then why to use AOD, as long as I know it is mainly useful when your phone is sitting idle on the table, so you don't have to unlock your phone to check notifications.
Ganeshmp
We need info like this🙌,,,and thanks for it😊
manbat
No heating isse and battery problem in our s22 plus.you got faulted piece i think.
