Difference between Full HD+ and QHD+
(Topic created on: 03-06-2025 12:03 PM)
SoldierBoy
Does anyone feel any difference between the resolutions, apart from sharpness, such as battery drain or heating issues, after changing the resolution to QHD+?
Please share your experience.
5 Comments
Yes,
Once you switch from fhd to qhd your device become hot, laggy and choppy during charging, gaming or heavy usage. Battery drain increase 10% approx
If you like my reply. Plz accept as a solution to click on the three dot of the right corner of my reply section.
Thanks
RIPA35
There is difference in resolution but no difference in battery drain
Rahulsha18
Yes, mine new phone bought five days back on flipkart., i did all the current update. Its getting hot all the time when using insta or fb., and qhd also makes more heating and battery drain ...if i trun on 5g thats make very worst Samsung need to pay attention for this.
