08-09-2025 09:17 AM (Last edited 08-09-2025 09:48 AM ) in
Galaxy S- Mark as New
08-09-2025 09:43 AM in
08-09-2025 09:52 AM in
08-09-2025 09:57 AM in
Galaxy SYouTube or other media playing apps are fine and good. Only Netflix I'm experiencing this.
08-09-2025 05:18 PM in
Galaxy SDear Samsung Member,
● Check app cache: Settings > Device care > Storage > CLEAN NOW.
● Reset the device Settings: Settings > General Management > Reset settings>Reset all settings to their default.
3. If you do not remember password then advise to reset (Forgot password) your Google account.
