Device not supported problem
(Topic created on: 02-08-2025 01:43 PM)
Prakash070
Beginner Level 4
I have connected USB-C headset jack adaptor to make use of a wired 3.5mm headset in galaxy s23 ultra But it's not getting connected
Show massage as
The Connected USB device isn't supported.
3 Comments
Prakash070
Beginner Level 4
Anshul9897
Use a samsung compatible adapter
cs_member10
Dear Samsung Member,
As per your query, we want to inform you that If you are using a galaxy phone that supports the USB Type C, then you can purchase a headsets jack adapter (USB Type C to 3.5mm).
1. Connect the jack adapter to your phone first.
2. Then connect the 3.5mm Headsets to the jack adapter.
