3 weeks ago in
Galaxy S- Tags:
- SamsungS25U
3 weeks ago in
Galaxy S- Mark as New
3 weeks ago in
3 weeks ago in
Galaxy SDear Samsung Member,
Note: Kindly use genuine Samsung charger.
1.Disable auto restart function, there are two methods to disable auto restart function:
Settings > General management > Reset > Disable Auto restart (if enabled).
If the issue has not been resolved, then follow;
2.If you are facing this issue after installing any new application, then uninstall that application:
Settings > Apps > desired app > Uninstall > OK.
3.If the issue is still not been resolved then, update software:
Go to Settings > Software update > Download and install > Checking for software update > Software update available > Tap on Download > Downloading updates > Tap on Install now
4.If the issue still persists, then reset the settings: Go to Settings > General Management > Tap on Reset > Tap on Reset settings.
5.If the issue is still not been resolved, Reset the device:
IMPORTANT:
• If you do not remember it, then reset (Forgot password) your google account.
• For this:
If the issue still persists, after performing all troubleshooting steps, would request you to please visit the service center. Below is the link to find nearest service center
http://www.samsung.com/in/support/servicelocation/
