One UI 7 Battery Drain Issue Resolved with June 2025 Security Patch
(Topic created on: 06-30-2025 08:50 PM)
솜나스
Initial Battery Drain Concerns
• After updating to One UI 7, many Samsung Galaxy users noticed that their phone’s battery started draining faster than usual.
• This issue mostly affected flagship phones like the Galaxy S24 series and Galaxy Z Fold 5.
• Now, new information shows that the battery drain issue on One UI 7 devices has been fixed with the latest security patch.
The Fix: June 2025 Security Patch
• Even though One UI 7 brought a better look and new features, it made some phones drain battery much faster than before.
• Now, it looks like Samsung may have fixed this problem quietly through the June 2025 security patch.
User Reported Improvements
• Some Galaxy S24 and Z Fold 5 users are saying that their battery life got much better after installing the June 2025 security update.
• One user even said their Galaxy Z Fold 5 battery life improved by “400%,” while Galaxy S24 and S24+ users also noticed improvements, but not that big.
• The June update started rolling out earlier this month for both the Galaxy S24 series and Galaxy Z Fold 5 models.
Purpose of the Update
• Usually, security updates are made to fix bugs and close security gaps.
• But sometimes, they also help improve how the phone runs, including battery performance.
• It also updates several apps to the new available version to bring new features, bug fixes, and changes.
User Experience and Impact
• Now, users are noticing improved battery life with this update.
• Even though Samsung hasn’t officially said anything about fixing the battery issue, some users believe the update helped.
• If your phone’s battery has been draining fast since the One UI 7 update, you might want to check if the June update is available for your device.
• Some users are already noticing better battery life.
3 Comments
Nandu48
But still battery drain increases in A53 after June security update
MK2204
Yes same with me. Battery drain fast even at standby.
thakords
Everyone was saying may security patch had solved battery issue but i don't think soo it was correct even my s24 started draining battery faster so i decided to do not download any security or any other software update!!
