Changing apps using navigation issue
(Topic created on: 11-19-2025 01:38 PM)
priyank09
It seems that the navigation gestures have become a significant issue, causing apps to disappear from the navigation bar. This problem is quite frustrating, especially for users who rely heavily on these gestures for their daily tasks. It's important to address this issue promptly to ensure a smooth and efficient user experience. We should consider finding a solution that minimizes or changes these navigation gestures without compromising functionality. It would be greatly appreciated if a solution
5 Comments
This issue is present since one ui 7
goodthings
Kindly complaint to Samsung customer care support through Samsung Members App as a error report also send log files along with this error report for this issue and wait for next update it's maybe fix it by Samsung team soon. If you like Please accept it's as a solution it's help to others users also, click on 3dots in my reply section and click on accept solution. Thanks.
goodthings
You're welcome to here.
cs_member10
Dear Samsung Member,
We appreciate you taking the time to share valuable comments and taking your valuable feedback. We are continuously working to make our products better and more efficient.
Kindly share the log file regarding issues. Also, share video clips and images for better understanding. This will help us to further investigate and resolve your issue.
To share the log file: Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send.
JungkookA16
bhai gestures navigation mei jb ek app se dusre app mei swipe krke jaate h toh wo issue hora h mere phone mei after oneui 8.5 update..... issey phle ye issue nhi tha
