11-27-2024 10:31 AM in
Galaxy S- « Previous
- 1
- 2
- Next »
11-27-2024 12:28 PM in
Galaxy SThis problem seems to be more noticeable when switching between the 3x and 5x lenses, and some users have reported that the image becomes blurry or shifts during this transition.
While some users believe this might be a hardware issue, others think it could be related to the camera's auto lens switching feature.
To troubleshoot this issue, you can try turning off the Auto lens switching feature in the Camera Settings. Some users have reported that this helps reduce the image shift.
However, if the issue persists, it's possible that it might be hardware-related, and you may want to contact Samsung support or visit an authorized service center for further assistance.
Please do check these links below.
https://forums.androidcentral.com/threads/s24-ultra-camera-issue-help-please.1064985/
https://saminsider.com/galaxy-s24-ultra-camera-shift-issue-when-zooming/
If this reply answered your query please mark my reply as "resolved" by clicking 3 vertical dots on top right of my reply. Thank you 😊
11-28-2024 09:17 AM (Last edited 12-04-2024 10:43 AM ) in
Galaxy SDear Samsung Member,
● Kindly disable the Shutter sound.
Path: Camera app> Settings> Swipe to and tap the switch next to the Shutter sound to disable it.
● Reset the camera settings: Tap on Camera>Settings>Reset settings>Reset.
● Clear camera application data: Apps>Camera>Storage>Clear Data
● Check app cache: Settings > Apps > Camera> Storage > Clear Cache.
● You can reset your device by following the steps:
If the issue persists, kindly report the problems with a log file. To share a log file, Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> select the appropriate issue category> Type your query and send.
11-29-2024 09:18 AM in
Galaxy Sand I have reported the problem with a log file.
- « Previous
- 1
- 2
- Next »
