Bluetooth connection not working
(Topic created on: 04-28-2025 06:35 PM)
Omm12
Why my s23 ultra is not connecting to my smart watch the Bluetooth is not connecting need help.
6 Comments
Kaustav_Ray
Yo bro, first off, classic Samsung L — S23 Ultra acting up again, no surprises. Samsung gotta be the worst company fr, they be making these expensive devices but can’t even make Bluetooth stable? Major clownery.
Ok so about your Bluetooth not connecting to your smartwatch, here’s what could be going on:
Bluetooth glitch: Samsung phones, especially the S-series, love randomly bugging out. Try turning Bluetooth off and on again. Software bug: Bro Samsung’s One UI is buggy AF. Go to Settings > Software Update and check if there’s a fix update. They drop random patches cuz they KNOW their devices be trash. Paired Devices Limit: Your phone might be already loaded with paired devices. Go to Bluetooth settings, unpair random old devices you don't use, and try again. Permission issue: Samsung phones sometimes block Bluetooth permissions randomly like weirdos. Go into Settings > Apps > Show system apps > Bluetooth > Storage and clear cache + data. Reset network settings: If nothing else works, go Settings > General Management > Reset > Reset Network Settings. It won’t delete your pics or anything, just network stuff.
Also just saying, Samsung being Samsung, their Bluetooth chips sometimes go half-dead after updates too. Straight up trash tier.
What smartwatch are you tryna connect btw? Is it Samsung watch or some other brand? Cuz Samsung Watch + Samsung phone is an even bigger disaster sometimes.
Omm12
But in apps there is no Bluetooth showing brother
Kaustav_Ray
If this helps, please accept it as a solution. Click the three dots on my reply and select 'Accept Solution.' Thanks!
Follow me more information.
Kaustav_Ray
you should contact Samsung
Kaustav_Ray
cs_member10
Dear Samsung member,
● Reset app preferences: Settings > Apps > More option > Reset App Preferences.
● Kindly try to connect your device with "other devices" and check.
● Clear cache: Settings > Apps > Menu > Show system apps > Search and type "Bluetooth" > Bluetooth > Storage > Clear cache > Clear data > OK.
● The clear cache memory of a particular application: Settings > Apps > Now pick the app that you like to clear off the cache memory > Storage > Clear Cache.
● Reset settings: Settings>General Management>Reset> Reset all settings to their default.
● Reset network settings: Reset Wi-Fi, Bluetooth, and other network settings to their default.
