Biggest problem solved in s21fe
(Topic created on: 12-23-2023 08:51 AM)
VyomTrivedi
I am having S21fe(exynos) and was facing the biggest problem in s21fe, which is battery backup. After one ui 6 update, the problem of battery backup is solved to a great extent. Before one ui 6, the ideal battery drain was around 5 to 6 % overnight but now it's around 2 - 3 and SOT is far better than before.
So, I am happy with the update thank you 😊
11 Comments
Santhoshsomu
Can you share latest battery backup from 100 to 0%?
VyomTrivedi
VyomTrivedi
Krishan15
Enjoy 😉
xaid
What about camera performance?
VyomTrivedi
Haven't noticed any changes clicked yesterday 20231222_173523_1000085946_1703246724.jpg
xaid
Are you sure , people are complaining with front camera downgrade
cs_member10
Dear Samsung Member,
Thank you for sharing your feedback. We are continuously working to make our products better and more efficient.
yogiSR09
my battery backup is degraded after the update
