Knightfury
01-16-2017 06:29 PM in
Guys,
My screen almost takes 50 percent of the battery. How can you reduce the battery drop? Please help me out.
7 Comments
S7UserSam
01-16-2017 06:56 PM in
enable power saver, reduce screen brightness, disable background apps, disable location, disabled Bluetooth and mobile data if unused, disable sync.
S7E1
01-16-2017 07:01 PM in
Enable grayscale, use black wallpaper. (S7's screen close the pixel for black color. So the screen is not using battery for black colors.)
abbas2
01-16-2017 07:56 PM in
S7E1
01-16-2017 08:47 PM in
What happened?
abbas2
01-16-2017 09:25 PM in
nothing just for fun😸
DGMASTER
01-16-2017 10:54 PM in
set apps on "always save power"
and uninstall less used apps
sorry for bad english...😕
S7E1
01-17-2017 01:41 AM in
You explained well the thing that you want to tell. Not so bad :)
