Battery
(Topic created on: 06-20-2024 10:24 PM)
sracuka
This thing is munching on my battery it has consumed 1.1 percent how to prevent it's battery use by 0.9 percent
17 Comments
Not applicable
U can't
cs_member10
Dear Samsung Member,
As per your query, we request you kindly share the log file. Also, share video clips and images for better understanding. This will help us to further investigate and resolve this issue.
Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
Oldy47
Only option for you is to root and boycott Google service's which I assume most people can't so live with it.
sracuka
The problem is not that it is consuming but it is that the consumption is more it should be less than 1 percent
Oldy47
Yes I checked mine and for 14.5 hour's of usage my consumed 0.6% but other things are different then yours, maybe your dependence on Google apps are more then mine ? 1718963163125.jpg
sracuka
What google services are installed in your phone like I have the all basic services, even I disabled google feed for the sake of this, still it is not working.. under the hood I am unable to understand what is actually going on
Oldy47
I only use Google assistant, chrome, playstore, and maps when traveling.
I think you should off certain things like
discover from home screen & Google app
Auto-updates.
Btw. Even if it take 1-2 battery battery does it really matter? It has to work with almost every thing in your phone and still consumes 1% of battery . I think it's optimised enough and consume battery as per usage of user.
sracuka
If it consumed less than or equal to 1 percent I am ok with that but it is racing more than 1 percent.
Oldy47
0.1 % really a big number I see. Why don't you go to court to resolve this huge matter. Maybe Apex court can help .
Enjoy the life man it's already short . Stop worring about 0.1 battery of your tool.
