Battery ๐Ÿ”‹ issues
(Topic created on: 05-21-2025 03:12 AM)
shezada
Hey samsung please solve battery ๐Ÿ”‹ drain issue for s24 ultra 7.0 update
8 Comments
SuMiT12301
Turn off -
- AOD
- Location
- Background processing
- Some app notifications
- Reduce the One UI 7.0 animation scale from developer options.
- Set the screen timeout to minimum.
- Turn on Dark mode.
This is conserve more battery at this moment.๐Ÿ˜Š
bijayk
Aagar sab kuch off hi karna he toh flagship phone lene ka fyda hi kya he
SuMiT12301
Battery will drain in this update. It is most likely to get fixed with the future updates.
NOMAฤ
Also turn off the phone, so that no battery life is wasted.
Shonzzzz
Nice posthttps://r2.community.samsung.com/t5/Galaxy-Gallery/s24-fe/td-p/19464538?src=ShareByUserCM Please like my post
Shonzzzz
BiRdMaN
Yes, many users have reported experiencing similar problems. This can be due to the phone re-optimizing itself after the update or apps needing to be optimized for the new firmware.
Add apps to the "deep sleep" list to prevent them from running in the background and draining battery.
Clear app cache to remove temporary data that can impact performance and battery usage.
Resetting battery statistics can sometimes help.
Adjust background usage limits in Settings > Battery and device care > Battery > Background usage limits.
Choose options like "Put unused apps to sleep" or "Sleeping apps" to restrict background activity.
If you find this helpful, kindly accept it as a Solution. It helps others
Tap the 3 dots on my reply and select "Accept Solution." Thank you ๐Ÿ˜Š
cs_member10
Dear Samsung member,
9. Reset the device:
IMPORTANT:
โ€ข Kindly create data backup of your device via SMART switch mobile application or http://www.samsung.com/in/support/smartswitch pc suite.
โ€ข Remember google password before resetting the device because it is required during initial setup.
โ€ข If you do not remember it, then reset, (Forgot password) your google account.
โ€ข For this:
โ€ข Open Gmail (https://accounts.google.com/servicelogin) > forgot password >Select ""try another way"" > Next > Enter a new password > Next
