Battery issue & heat issue
(Topic created on: 01-30-2024 08:36 PM)
RavisinghT
S22 to buy karna bekar hain kyounki battary bactup itna better nahi hain. Heating issues hain,
Kriprya apni rai de .
7 Comments
I am also facing this problem not of heating but battery Drain It's not problem of phone . It's problem of Size of phone It's Compact phone 📱
AJAB_MORIA
"Because of 5G network."
Wait for next updates, restart your phone (in your free time) to avoid such problems.
Rohit_S22
Vary bad battery backup.
In normal use, require charge 2 times in a day.
cs_member10
Dear Samsung Member,
As per your query, please visit this mentioned link to resolve the heating issue: https://www.samsung.com/in/support/mobile-devices/how-to-prevent-the-overheating-of-your-galaxy-devi...
We would request you to kindly perform the following steps to resolve the battery issue.
We want to inform you about the Samsung Members app (Battery Status (Battery life + Battery Capacity).
You can check the "Battery Status (Battery life + Battery Capacity)" test using the Samsung Members app.
Battery life depends on how the battery is used. Note that different devices have different battery life. The expected battery life for your model can be found in the manual.
We would like to inform you about the standard charging procedure (charge in one go instead of charging many times as it affects the life span of the battery and battery performance).
Charge in one go instead of charging many times as it affects the life span of the battery and battery performance
Perform Battery Optimization
Settings > Select Device Maintenance/Device Care/Battery and device care > Optimize > Optimize all options like Battery, Storage, and Memory.
Turn off Wi-Fi, GPS, Bluetooth, etc.
Turn off unused functions like Wi-Fi, GPS, Bluetooth, and location settings when not using them: On the home screen swipe down the notification panel > Turn off Wi-Fi, GPS, Bluetooth, and other connectivity features when not using them.
Check device network fluctuation
Kindly check whether the mobile network fluctuates frequently or if the network signal is low in your area. In both cases, the battery will drain considerably fast.
Recommendation: We recommend you avoid using it in areas with low network/fluctuation.
Reduce display brightness level.
Kindly set the device display brightness in auto mode (If available).
Adjust screen timeout settings: Settings > Display > Screen timeout > Select minimum screen timeout.
Check and update the App: Kindly check which application or interface is using more battery from device care. And try to update the app or avoid using that app.
Close background running apps.
Close all the background running apps when not using them,
Turn off auto sync of e-mails, app data, etc.
We request you turn off the auto sync option, it will stop the synchronization of the device with the server & reduce the battery drainage.
The steps to turn off auto sync are:
2. Turn off the auto sync option.
Check your device in safe mode: https://www.samsung.com/in/support/mobile-devices/safe-mode-on-samsung-phones/
Reset your device: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-mobile-how-to-perform-a-factory-res...
In case the issue still occurs kindly visit the service center for a physical inspection of your device. You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
RavisinghT
Se sab kar liya shrimaan
devsg
Get ready for samsung bot answers .
RavisinghT
Solulitions?
