Battery drain issue after one ui 7 on my galaxy s24+
(Topic created on: 05-18-2025 09:57 AM)
Sri_Ram_Prateek
Drastic reduce in sot after one ui 7 update. Thought it will be nrml after some days of update but it's getting worse.
Edit: using it with location off, fhd+ resol., battery saver, lite performance modes but still less sot. Why samsung? Then what is the use of lite performance mode and battery saver modes?
13 Comments
Alokyadav6983
Same issue with S24 ultra too
Aarish04
Do you also notice that while using instagram phone is getting hot and it is consuming more battery then it should be, is it only me or you guys are facing same problem as me
I didn't observe especially in instagram. But phone usually get warmer even for lite tasks although it is in lite performance mode.
Mani4
Please file a complaint with Samsung customer support through the Samsung Members App, including the error report and log files related to this issue. Then, wait for the next update, as the Samsung team may address the problem soon. If you'd like, you can mark this as a solution, which will also help other users. To do so, click the three dots in my reply section and select "Accept Solution." Thank you!
Mani4
try to clear cache partition, if not solved format the device after backup
dave7
Same issue with my S24plus after one ul 7.0 update
bijayk
Same ..2din se kuch jdya hi battery drain ho rha he mere s24 plus me ..
goodthings
goodthings
Your's most welcome to here.
