Battery issue
(Topic created on: 05-18-2025 06:53 AM)
bikramshui
Hi,
 After the update the battery is draining just like nothing ,even after 10 percent churge its just staying 20 mnts in normal usage and its staying only upto 4 % battery after 4% its switching off
5 Comments
AnverAli
I am also facing battery Drain after one ui 7 update
goodthings
goodthings
Your's most welcome to here.
cs_member10
Dear Samsung member,
9. Reset the device:
IMPORTANT:
• For this:
