3 weeks ago in
Galaxy SSolved! Go to Solution.
3 Solutions
3 weeks ago in
Galaxy S• Wipe Cache Partition – Boot into recovery mode and wipe cache partition to clear outdated system cache.
• Check for Rogue Apps – Go to Settings > Battery > Usage and check if any app is unusually high. Uninstall or restrict if found.
• Update All Apps – Ensure all apps are updated via Galaxy Store & Play Store to maintain compatibility with One UI 7.
• Disable Unused Features – Turn off Always On Display, Location, Bluetooth, or 5G if not needed.
• Use Power Saving Mode – Enable medium or maximum power saving for better idle performance.
• Reset App Preferences – Settings > Apps > 3-dot menu > Reset app preferences can help fix hidden misconfigurations.
• Report via Samsung Members – If the issue persists, report it through the Samsung Members app for logs and patch feedback.
3 weeks ago in
Galaxy SAdd apps to the "deep sleep" list to prevent them from running in the background and draining battery.
Clear app cache to remove temporary data that can impact performance and battery usage.
Resetting battery statistics can sometimes help.
Adjust background usage limits in Settings > Battery and device care > Battery > Background usage limits.
Choose options like "Put unused apps to sleep" or "Sleeping apps" to restrict background activity.
If you find this helpful, kindly accept it as a Solution. It helps others
Tap the 3 dots on my reply and select "Accept Solution." Thank you 😊
3 weeks ago in
Galaxy S- Mark as New
3 weeks ago in
3 weeks ago in
3 weeks ago in
3 weeks ago in
2 weeks ago in
Galaxy SDear Samsung member,
9. Reset the device:
IMPORTANT:
• For this:
