Battery draining S24 Ultra
(Topic created on: 10-18-2024 04:59 PM)
Nijju786
Is it ok
9 Comments
ovais001
After updating my s22 ultra my phones display is flickering please samsung replace my display free of cost as its not my fault nor i broke my display
Oneui_new
Have you tried 60hz display mode? Is it still flikering in 60hz?
safwan7165
Beginner Level 3
Its ok
Nijju786
Really 😮
Wodehouse
Nijju786
But in light mode, I am not able to use 5G, bro. 😔😔
Wodehouse
I use 5G in light mode. I have S24. You should too 😊. It only reduces processor speed to conserve battery and run cooler. Nothing to do with 5G. If you have enabled power saving and disabled 5G then 5G won't work. Even here you can toggle off 5G disable. If my reply helped mark my reply as resolved.
Nijju786
No, it's not a solution, bro. Even in light mode, 5G doesn't work.
cs_member10
Dear Samsung Member,
As per your concern, we would request you kindly perform the following steps to resolve your issue by the given links.
● Galaxy device Battery drain issue: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
→ Update the software if available: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-smartphone-how-to-update-software/
→ You can reset your device by following the steps.
If the issue still occurs, please visit the service centre for a physical inspection of your device. You can locate your nearest service centre with this given link: https://www.samsung.com/in/support/service-center/
