Battery drain issue of Galaxy S22
(Topic created on: 10-03-2024 10:20 AM)
MyS22
After one ui 6.1.1 the battery life of Galaxy S22 is very poor. It's give me just 2 hours of sot in 120hz(normal usage). And in power saving mode it's give 3 house of sot. That's very panic for me. Atlest it gives 5–6 hours sot is good for me and all the users of Galaxy S22
7 Comments
cpj31
If you can try, which I tried and it is working for me, Please do reset all setting.
MyS22
My picture or Account removed????
cpj31
No nothing remove, as you have to do just setting reset
cpj31
If you like and find my comment useful then please click on the 3 dot menu on my comment and accept my solution.
goodthings
Kindly reset factory data with backup then try to it's again. If you like please accept as a solution it's help to others users also, click on 3dots in my reply section and click on accept solution. Thanks.
goodthings
Your's most welcome to here.
cs_member8
Dear Samsung Member,
As per your concern, we would request you kindly perform the following steps to resolve your issue by the given links.
Galaxy device Battery drain issue: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
You can reset your device by following the steps.
If the issue persists, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open the Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select Error report > select the appropriate issue category> Type your query and send).
