Battery drain issue in S21FE 5G
(Topic created on: 12-14-2023 11:56 AM)
Chinna9951
Even when I have updated to one ui 6.0 the battery drain issue still remains. I don't know why samsung is not focusing on battery issue.
Although I have used more than 10 samsung models All the models That performed very well when it comes to battery performance.
But the samsung (S21FE 5G) SNAPDRAGON VARIANT Has very much worst performance when it comes to battery.
I hope after seeing this that samsung will fix these battery issues in samsung S21fe 5g .
13 Comments
iamrohitkm
I think it will be fixed on exynos. In yours it will be fixed in next update.
Livealone
Exynos version will get the update after fixing the battery drains issue.
That's why Samsung has given the update in SD version first.
Just enjoy the new new features bro 🤭
BADTHINGS
Chinna9951
Then what about who bought snapdragon variant
Livealone
Moye moye... 🤭😉
Jassimsheik28
Is your battery drain issue fixed?
Naumanuq
Yeah , I also have a very bad battery performance experience from S21 Fe Exynos variant, but then someone said that switching the refresh rate from 120 to 60hz can give better results and after switching to 60hz the results are better and battery performance has been good, you can try that too untill samsung fix the issue in future update.
Chinna9951
I tried but there is no use
