04-05-2025 05:32 AM in
Galaxy SSolved! Go to Solution.
04-05-2025 04:21 PM in
Galaxy SDear Samsung member,
3. Check device network fluctuation. Avoid usage in areas with low network/fluctuation.
9. Update software: Go to Settings > Software update > Download and install > Check for software update > If Software update available > Download > Downloading updates > Install now
10. Reset the device:
IMPORTANT:
• For this:
If the issue still persists, after performing all troubleshooting steps, would request you to please visit the service center. Below is the link to find nearest service center
http://www.samsung.com/in/support/servicelocation/
04-05-2025 05:46 AM in
Galaxy S- Mark as New
04-05-2025 07:58 AM in
Galaxy S1 Enable Power saver
2 Enable performance mode light
3 Enable adaptive power saving instead of basic
4 Enable adaptive brightness
5 Disable AOD
6 Enable extra dim
7 Change display to natural
8 Screen time out to 30 secs (system default)
9 Record videos in FHD
10 Restrict gaming to HD or FHD and slower frame rate
11 Switch to dark mode
12 Disable near by device scanning
13 Disable WiFi scanning
14 If 5G is unavailable change network to LTE/3G/2G
15 Allow the battery to drain completely and recharge,say once a month.
16 Enable auto restart
17 Run device care
18 Disable apps running in background.
19 Disable RAMplus if you dont use memory intensive apps and do heavy multi tasking. Available RAM usually around 2 to 3 Gb is more than sufficient for normal tasks.
20 Uninstall bloat ware that came with your phone,eg. Spotify,LinkedIn etc.
You can mix match the steps above and arrive at a usage based on your needs.
If this reply answered your query please tap 3 vertical dots to the right of my reply and tap "Resolved". Thank you 😊
04-05-2025 08:57 AM in
IMPORTANT:
• For this:
