Battery Life of Galaxy S21 Ultra
(Topic created on: 03-15-2021 09:13 AM)
Hey Members,
Today I am doing to showcase my battery life of the Samsung Galaxy S21 Ultra 5G! 😎
I am running on max 120Hz Adaptive and 1440p WQHD+, I got 7 hours and 32 minutes of Screen on Time with a discharge of 1 day and 5 hours at 12%, this is truly remarkable. I didn't have to worry about turning on power saving mode or toggling off any useful features which is fantastic. Furthermore if you notice my applications usage I used YouTube the most well not only that but I played most of the videos at 1440p which would consume a lot of battery life however Galaxy S21 Ultra 5G was strong enough and the battery life lasted the whole day! I can't wait to share more battery statistics with you after every new update!
If you have missed my recent post about the Galaxy S21 Ultra's Performance than check out the link below!(https://r2.community.samsung.com/t5/Galaxy-S/My-Impression-of-Galaxy-S21-Ultra-Performance/td-p/7462...)
Let me know in the comment section if you got any queries :)
14 Comments
Samsung_specialist
Hi Ambassador!Thanks for this!
Let us know a few more details you noticed with the battery life performance...we want to know more about the epic Galaxy S21 Ultra 5G!
I noticed that if power saving mode is enabled I would get an extra 1-2 hours screen on time (it depends on my usage) still a big bonus for that Ultra battery life! Will share more details about this soon 😃
Samsung_specialist
We are looking forward to it!
UserAdik
eventually when you get a software update and it will be kind of a downgrade and then a new phone will be launched world wide for example and my example might come true as well Galaxy S22
Wiping the data from recovery normally fixes the issues. If updates slows down the device share the report on help section, Samsung rep will share your feedback and log to relevant department to release a patch or solution with upcoming update. They have helped me in the past for my Galaxy S6 edge within 3 days. I am sure you will get a satisfied outcome if not you can always contact me and I'll look for a workaround
UserAdik
maybe I wasn't the lucky one
UserAdik
how many MAH battery you have?
Unfortunately I didn't check the remaining mAh nor is there an app that can accurately calculate the remaining mAh. If you got any I'd be glad to try them out.
UserAdik
do you have the phone box it will say on there
