Important Notice: One UI 7.0 Battery Drain Issue on Galaxy S24 Ultra
(Topic created on: 05-13-2025 10:48 PM)
Rahul_Radhakrishnan
We’ve received feedback from many users reporting faster battery drain after updating to One UI 7.0 on the Samsung Galaxy S24 Ultra.
While this may not affect every device, it is a known issue and we're here to help.
Common Ways to Improve Battery Life:
1. Restart your device after the update to complete background optimization.
2. Go to Settings > Battery > Background usage limits and restrict unused apps.
3. Turn off Always-On Display and reduce screen brightness or timeout.
4. Disable unused features like Bluetooth, Location, and 5G when not in use.
5. Check Battery Usage in settings to identify any abnormal app behavior.
6. Keep all apps updated to their latest versions.
Please Note:
Samsung is aware of this issue, and a fix is expected in the next software patch update. We recommend keeping your device updated and checking regularly for the latest system updates.
We appreciate your patience and understanding.
Pruone
This will not work, as the new update is major, you need a complete factory reset to fix them.
