Battery Drains Fast
(Topic created on: 04-10-2018 12:34 PM)
Atiif
I received an update 3 or 4 days ago for CRC7 March Security Patch. Battery life ain't any better. In fact its the worse now. Its pretty annoying that I have to charge my phone 3 times a day. Is there anyone else facing the same issue?
5 Comments
turn off your Syncronising, GPS and wifi when you don't use your cell phone . when you want to stand by your phone on click on device maintenance 😋
Atiif
I dont sync my gallery and stuff. GPs and Location is always on battery saving mode. what I dont understand is What is the purpose of paying shit load of money for phone when you can't use your phone with its all functions on.
MdTajammul
they are saying don't use your device... just keep in your pocket or keep in ur table... then see. keep in stand by mode.. thats its... wow superbbbbbbb 🤯🤯🤯🤯
R009
my s7 is heating a lot after new update for security patch
go to mobile setting >device maintenance >see the tag symbol on the top right corner click on to see apps that cause your battery and heat up your cell phone uninstall this 3rd party apps if any one show in 😊
