Battery Draining too fast in idle condition. Galaxy s22
(Topic created on: 10-02-2023 03:24 PM)
John56
Even in the idle condition of the phone, why is the battery Draining so quickly? And also I turned on adaptive battery and processing speed set to optimized and all wireless connections(wifi,Bluetooth,nfc,location)are turned off.
I purchased this phone 3 weeks ago.
9 Comments
piyussh07
Screen on time is 30 minutes.
You've used smartphone for atleast 30 minutes, 30 minutes mein 13% drain to jyada hai, mere s21fe mein 30 minutes = 10% drain
Try some
- routines
- wipe cache partition
- battery calibration
- factory data reset
- or better wait for next monthly patch
John56
Ok, thanks for your suggestion
piyussh07
See on s21fe. 30 minutes use and 10% lostScreenshot_20231003_073201_Device care.jpg
CODM6567
Use Dark mode(if brightness >40%)
Use Dark wallpaper
Turn off adaptive brightness
Turn off quick share
Switch to light mode in performance profile
Put unused apps to deep Sleep
Turn on location services for while using apps only
AOD as Tap to show
Turn off 5g
You can also try these routineScreenshot_20230911_234405_Samsung Members.jpgScreenshot_20230911_234409_Samsung Members.jpgScreenshot_20230911_234412_Samsung Members.jpg
cs_member10
Dear Samsung Member,
Charge in one go instead of charging many times as it affects the life span of the battery and battery performance
Perform Battery Optimization
Settings > Select Device Maintenance/Device Care/Battery and device care > Optimize > Optimize all options like Battery, Storage, and Memory
Turn off Wi-Fi, GPS, Bluetooth, etc.
Turn off unused functions like Wi-Fi, GPS, Bluetooth, and location settings when not using them: On the home screen swipe down the notification panel > Turn off Wi-Fi, GPS, Bluetooth, and other connectivity features when not using them.
Check device network fluctuation
Kindly check whether the mobile network fluctuates frequently or if the network signal is low in your area. In both cases, the battery will drain considerably fast.
Recommendation: We recommend you avoid using it in areas with low network/fluctuation.
Reduce display brightness level
Kindly set the device display brightness in auto mode (If available).
Adjust screen timeout settings: Settings > Display > Screen timeout > Select minimum screen timeout.
Check and update the App: Kindly check which application or interface is using more battery from device care. And try to update the app or avoid using that app.
Close background running apps
Close all the background running apps when not using them,
Turn off auto sync of e-mails, app data, etc.
We request you turn off the auto sync option, it will stop the synchronization of the device with the server & reduce the battery drainage.
The steps to turn off auto sync are:
2. Turn off the auto sync option.
Check your device in safe mode: https://www.samsung.com/in/support/mobile-devices/safe-mode-on-samsung-phones/
Reset your device: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-mobile-how-to-perform-a-factory-res...
In case the issue still occurs kindly visit the service center for a physical inspection of your device. You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
mHappiee
Do you always keep your WiFi ON ?
John56
No
mHappiee
Okay
You can check this post... I also had this issue, I installed an app to check internet usage and found that some app/service was running in background which was draining battery.
https://r2.community.samsung.com/t5/Galaxy-A/Battery-going-down-without-any-usage/td-p/11112518?src=...
John56
Ok thanks
