Battery Drain Issue Solved
(Topic created on: 05-27-2025 07:27 PM)
Mirage02
For users experiencing battery drain after updating to One UI 7 on their S23 (or S24/S25), this solution may be helpful. I recently experienced similar issues on my S23 after the update, but wiping the cache partition (videos demonstrating this process are available on YouTube) improved my battery life. While not a dramatic improvement, it's noticeable. I'm unsure if this will work on the S24/S25 series, but I hope it does. Let me know if it work for you guys or not.
9 Comments
Affan_Mir
Can you elaborate?
Mirage02
Since I've cleared my wipe cache partition ( you can check it out on yt how to do ) it won't delete your data just clear some unnecessary cache files. I see a slightly improvement in my battery backup. Before doing it please check it out some videos on yt for more details.
Rajat_09
Wiping cache partition not helping the battery drain . Its only help lag and stuttering on the device and delete unnecessary data thats it.
Mirage02
I don't have much knowledge about tech, May be you are right but since I've cleared wipe cache partition. I see a slight improvement in my battery life on s23. Hopefully it work for you all.
Affan_Mir
I also tried it
6e❤
bhghwan
If you factory reset it will be more helpful.
Mirage02
I've done this thing as well but I see nothing difference infact, I feel like after factory reset, My phone get lags a little bit. May be it works out for some
cs_member10
Dear Samsung member,
9. Reset the device:
IMPORTANT:
• For this:
