10-27-2023 11:09 PM in
Galaxy S- Mark as New
10-27-2023 11:12 PM in
10-27-2023 11:17 PM in
10-28-2023 03:52 PM in
10-31-2023 11:35 AM in
Galaxy SDear Samsung Member,
As per your query, we would request you to kindly perform the following steps to resolve your issue. However, we are taking your valuable feedback regarding this.
Galaxy device sound issue:
Clear Sound Picker data: Settings>>Apps>>Filter and Sort>>Enable "Show system apps">>Ok>>Search Sound Picker>>Tap on storage>> Clear data of Sound Picker.
Clear SoundAlive data: Settings>>Apps>>Filter and Sort>>Enable "Show system apps">>Ok>>Search SoundAliver>>Tap on storage>> Clear data.
Clear Adapt sound data: Settings>>Apps>>Filter and sort>>Enable "Show system apps">>Ok>>Search Adapt Sound>>Tap on storage>>clear data
Reset app preferences: Settings >> Apps >> Three dots (Appearing at the top right corner) >>Reset app preferences >> Reset
Reset your device: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-mobile-how-to-perform-a-factory-res...
If the issue still persists kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
