Resolved! Solved
Auto call record feature not working on my S20 Ultra. What to do?
(Topic created on: 07-09-2021 01:34 PM)
Lalit110
I have auto call recording option enabled on my phone but the calls are  not getting recorded. I have rebooted the phone, turned off the setting and turned on again. Still not working. What to do?
Ps: please don't say factory reset.
AjuGeorge
Check whether your WiFi calling is turned on ... Call recording won't work with wifi calling...
3 Comments
AjuGeorge
Lalit110
Thank you so much Sir, that helped. Yes, wifi calling was on. I disabled it and recording is working fine now.
AjuGeorge
Thanks... Kindly mark this as a solution....
