Any solution to pwm samsung s23 ultra
(Topic created on: 03-07-2024 03:55 PM)
kawunderonald
I get headache and eye pain when using the s 23 ultra
5 Comments
I'm sorry to hear that. Headaches and eye strain from using devices like the Samsung Galaxy S23 Ultra can be quite common, especially if you're using it for long periods of time. Here are a few tips that might help:
1. **Take Breaks**: Follow the 20-20-20 rule - every 20 minutes, look at something 20 feet away for at least 20 seconds. This can help reduce eye strain.
2. **Adjust Display Settings**: Lower the brightness and adjust the color temperature to a warmer setting, which can be easier on the eyes.
3. **Reduce Glare**: If you're in a brightly lit room, reduce glare on the screen by adjusting your position or using an anti-glare screen protector.
4. **Use Blue Light Filters**: Many devices have built-in blue light filters or apps you can download that reduce the amount of blue light emitted, which can help reduce eye strain.
5. **Correct Positioning**: Ensure that the screen is at eye level and about an arm's length away. Looking down at a screen for a long time can strain the neck and eyes.
6. **Check Prescription**: If you wear glasses or contacts, make sure your prescription is up to date. Incorrect prescriptions can contribute to eye strain.
If the problem persists, it might be a good idea to consult with an eye doctor to rule out any underlying issues or to get personalized advice.
Zammi
In addition to above suggestions, I would like to add few more.
- Enable eye comfort shield.
- Change screen zoom level and font size to comfortable level.
- Switch to dark mode, that is comfortable.
- There are casual glasses, that blocks the light. That might give comfort to your eyes.
Hope these tips will be helpful.
Boy.. reduce brightness and select display normal(avoid vivid ) turned on eye comfort mode
Jayy390
Beginner Level 3
Im experiencing eye strain, dry eyes, blurry eyes at the end of a day.
Ive been with samsung for more than 10 years but the S23 Ultra is really hurting my eyes.
I used to have good vision but since having this phone I had to get prescription glasses because at the end of a day when using my phone more than usual, I couldn't see in front of me..
Whats interessting is that I got my phone throught corporate and 2 other coworkers got the phone at the same time as me and we all, after 8 month, wear prescription glasses.
Ive come forward to samsung with a official notice and we are considering a class action.
If you found anything helpful in the meantime, please let us know
kawunderonald
Use natural mode
