Android System Intelligence not compatible with S21Fe?
(Topic created on: 05-07-2023 11:04 PM)
SamCam
Hi Members,
Is Android system intelligence not compatible with S21 FE anymore?? Are all s21 fe users facing the same?
16 Comments
ɗáş
What is the use of this app ?
After this post I also check on my device it shows the same. By the way my device Galaxy M53Screenshot_20230507_235051_Google Play Store.jpg
SamCam
Seems it is the android AI??
ɗáş
I search about this some s22 ultra user also posted this kinda post
There mention they noticed it after android 13.
I think this is normal with android 13 device 🤔
hunter1063
It's no longer required. Uninstall it.
SamCam
It is system app... why is it not required could you please explain
hunter1063
It's contents have been shifted to core system.
JithinAjith
Expert Level 3
Same issue in galaxy A51
Ujjwal9
I am not getting the error, it shows compatible for my S21 FEScreenshot_20230509_121347_Google Play Store.jpg
SamCam
Do you have the latest April and latest Google play system update?
