Android System Intelligence not compatible with S21Fe?
(Topic created on: 05-07-2023 11:04 PM)
SamCam
Hi Members,
Is Android system intelligence not compatible with S21 FE anymore?? Are all s21 fe users facing the same?
16 Comments
Ujjwal9
Yes device is up to date
SamCam
Sid_Karna
Bro try to update it from Galaxy store if it's available there. Otherwise, try clearing the cache of playstore, restart the device and try again.
SamCam
Tried all, but seems not supporting anymore after 5.1... Just check once from your end if it is available.
Sid_Karna
It's not even showing for me in playstore 😂.
SamCam
Right. Go to Settring->Apps->Android System Intelligence->Scroll to bottom->App details in store. There you can see.
Sid_Karna
Ok bro, it's not showing any message like yours. But there is an option to uninstall it. Last updated on march 17.
