regarding fast charging problem
(Topic created on: 04-29-2020 06:03 PM)
anit07
Galaxy Note
After my lastest update on Samsung note 10 plus i am facing a issue in fast charging my device... Sometimes it support fast charging and display fast charging and sometimes it just charge normal from same charger..can u help me??
5 Comments
Dilli
Galaxy Note
when you see normal charging, just pull out the usb c from your phone and twist it to use other side and insert again. This helps sometimes.
Galaxy Note
There is something wrong with ur charging cable I guess
hedgehog
Galaxy Note
shut off fast charge then charge and see
or else charge in safe mode to check problem
change usb cable of adapter
charge through pc connection
clean your power socket in phone
RajasekarJKM
Galaxy Note
it may happen when the ambient temperature is high. the phone will get heat while plugged in. to counter the heat the device itself pull down the charging speed.
Samsung_Support3
Galaxy Note
Dear Samsung Member,
Be rest assured by following the given steps your issue will be resolved:-
1. We always recommend to use genuine Samsung charger for charging your device.
2. Check physical condition of USB cable, if any tear or bent please replace it with the new genuine one.
3. Check device in safe mode :-
Steps to enter into Safe Mode:- Press and hold the Power key, when Power off icon appears > hold power off icon.
Exit safe Mode:- Restart device.
Note:- If your device functions correctly in Safe Mode, it is most likely that the issue lies with a 3rd party application that can be uninstalled to resolve the problem.
4. Update software(If available):- Settings > Software update > Download and install > Install now.
5. Reset the device :- Setting > General Management > Reset settings.
Note :- Kindly create data backup of your device via SMART switch mobile application.
If issue still persist or for further assistance, kindly register your concern in Samsung members app (Samsung Member > Get help > send feedback > Ask question/Error report)
