NOTE 10 PLUS Charging problem
(Topic created on: 04-25-2020 11:51 PM)
MANISHKUMAR2404
Galaxy Note
After april 2020 update of Note 10 plus, phone getting warm during use and it takes too much time for charging. Kindly guide me regarding this type of problem because I already take all action which available on internet.
10 Comments
Galaxy Note
we couldn't do anything we are just uses like you.
VikasBidlan
Galaxy Note
first of all backup your mobile data like samsung cloud or google drive or pc then hard reset of your device. your problem should be solved because i have already faced that problem.
MiraclePanda
Galaxy Note
Well you can't do anything about it every note 10 users have this issue 🙄 after 2.1 update, the phone gets hotter than usual & due to that the phone charges slower than usual & there is new update on the way hope it can fix these issues.
MaverickSiD
Galaxy Note
Super fast charging is not been displayed on screen or screen lock while charging the phone with OEM charger and usb and also cannot find super fast charging toggle in battery settings, is it just me? did your issue get resolved? any solutions
available?
MaverickSiD
Galaxy Note
available?
MiraclePanda
Galaxy Note
r u using a 45w charger?
if you are using the charger which came with the phone then it will show fast charging not superfast charging & yes it works & toggle is available.
hedgehog
Galaxy Note
main reason for all to fail is bug instability you can either wait for next stable update or follow some advice and tips I could give you
1 use adaptive battery
2 use medium power save
3 prevent background apps from consuming data in battery device care
4 put unused apps to sleep
5 reduce some permissions given to apps that are not necessary for running of app
6 use dark mode
7 use location when necessary as in maps Google search or any location based app else constant use loads battery causing heating
8 prevent network inputs like NFC bluetooth WiFi from working together too many network inputs will cause heating and lagging
9 while charging keep phone idle
10 turn off auto sync use when necessary
11 reset phone settings once clear cache
12 if nothing works once try factory reset
13 charge in cool conditions as outside weather will be hot these days
I hope this helps because one ui bugs can be fixed by samsung when new updates come till then try these tips they could help to reduce battery heat up and loading so that smooth charging works and device runs smoothly
hedgehog
Galaxy Note
not every note 10 plus user
hedgehog
Galaxy Note
try a ove options they aren't from 8nternet even though they look like
they are my personal settings I mostly use whenever in trouble👍👍👍👍👍👍👍
