note 9 battery drain after September security patch.
(Topic created on: 10-17-2019 07:56 PM)
Balu332
Galaxy Note
I used to get sot of 5-6 hours earlier but when i upgraded to September security path my battery is draining continuously and now i am only getting sot of 3-4 hours. Is it same case with other note users?
5 Comments
Gst26
Galaxy Note
I am not Getting such issue with my Note9, though Earlier also & now also I Restricted background battery usage by most of the apps, which consumes unnecessary battery usage in background...So if you want to improve than you can also Restricts Background battery usage by Apps..But you choose battery Restriction for Apps Carefully, Since no System App/Mailing App is to be Restricted....
Balu332
Galaxy Note
Hi bro, thanks for the suggestion i have tried putting apps under restriction but still there no change in the sot it is still giving 3-4 hours.
Currently how many hours of sot your getting bro? And how old is your device..
Gst26
Galaxy Note
After Full charge It Normally works for 8-10 Hrs and it is almost 1Year & 2 months old (24Aug.18)..I don't play games but used to listen music with wired headphone, Using tweeter, Facebook, WhatsApp Frequently, Some times watching Movies on Amazon prime & Netflix, Using Adaptive Brightness, AOD , No Screensaver etc. this is how I am using my Note9..I also Reset it to Factory Resetting once in 4-5 Months (Done Thrice till now) after taking Backup...
KaziMahfuzurRahman
Galaxy Note
same problem here bro
Balu332
Galaxy Note
Getting same sot after putting apps under background restriction.
