note 8 battery issue
(Topic created on: 02-06-2019 11:02 PM)
raktimraj000
Galaxy Note
 I am noticing  battery issue in my device samsung galaxy note 8 .after the last security update..after updating my battery drains so fast..even if i put it in charge and also talk with others in phone then also battery drains rapidly. Whats the problem? The problem is in the update or does it is a bug or its my phones battery issue ? HELP !
9 Comments
arjit013
Galaxy Note
actually mine is performing much better after the beta update
uk29
Galaxy Note
yes even I m getting better battery life in pie beta..
raktimraj000
Galaxy Note
u got the one ui beta update ?
raktimraj000
Galaxy Note
Lol i didn't.. then just pushed a security patch update 15 or 14 days back.. maybe the issue is in my battery 😞
navneet0693
Galaxy Note
May be go to service center and get it checked. Also run device care
raktimraj000
Galaxy Note
yeah...😅
YashJariwala
Galaxy Note
My phone performs okay why don't you try and reset your device
admin_
Galaxy Note
"Thank you for Joining Samsung community. We would recommend taking some troubleshooting steps to further isolate what you may be experiencing.
Find troubleshooting steps on provided link http://www.samsung.com/in/support/skp/faq/1101689. Please let the us know what steps you have taken and if you have noticed any changes or improvements. This will help the Community to provide you steps without repeating any steps you may have already taken. Be sure to hit ♡ when you find an answer that works for you.
rahulkataria
Galaxy Note
oops
