note 10 plus charging issue
(Topic created on: 04-15-2020 05:12 PM)
7405ankit
Galaxy Note
Dear Community,
Recently i have noticed a slow charging in my device it use to take 1 hr 15 min to charge completely with all the general settings, now it takes almost 1 hr 30 mins to charge completely and sometimes a bit more than that. Is anyone else facing the same issue. Please share. Also, stay safe
Thank you,
23 Comments
7405ankit
Galaxy Note
try to understand currently there is lot of heat outside and tempreature play an umportant role here charge your phone in cool tempreture and try that you switch your device off and keep it ideal for 5/7 mins and then charge the phone in AC room or room which has cooler tempreature than normal one ..and then see it will charge the device much faster ..bcz samsung has kept a system which reduces the speed of charging if the device heats certain tempreature so keep you device's tempreature down and charge it ..you will see a good rise in battery and ..this is a temperory solution ..i think samsung will provide an update after situation gets back to normal
milindd
Beginner Level 3
Galaxy Note
thankyou for the suggestion. I'll definately try this.
WaleedAnjum9
Beginner Level 3
Galaxy Note
Hi Ankit , i agree with you brother.. have same issue.. now my mobile charge at 1 hr 30 and above that previously it used to get charge in 1 hr 9 mints...
And yes here at my place its too hot.. temp gone to 43 to 44°C and device is dame hot while charging... u might be saying right... will charge it in cooler temp but still i would say that permanent solution should come out by samsung becz this mobile drains the battery too fast so only thing copping out with that will be the fast charging atleast!...
And wire issue can also be the reason.. i use 45watt charger with display so it clearly shows less Amperes from previous days now it charge on 0.75A and previously it used to charge at 2.89A... so lets see how things roll on!!! Wait for latest software update .. weather to get cooler and finally the good quality wire!
thesaiswaroop
Beginner Level 3
Galaxy Note
I agree with you. My note 10+ is taking about 1hr 20 mins to charge from 10-100%
