note 10 plus battery
(Topic created on: 09-04-2020 11:14 AM)
Balu332
Galaxy Note
Did any one replaced note 10 plus battery as i enquired service center.... right now stock is not avilabe and they are asking me to wait for some time...... is it same in other areas...?
13 Comments
Dilli
Galaxy Note
So better wait for SC to contact you
S_Kumar73
Galaxy Note
I changed my note 10 plus battery on 24th August from Samsung service center in T.Nagar Chennai. I gave my phone 1 day, they replaced it and kept for 1 day for water test.
Balu332
Galaxy Note
After changing you notice big difference in battery backup bro is it simiar to new mobile backup
S_Kumar73
Galaxy Note
there is a big difference in my phone. previously when it reaches 5% it took only 2 to 3 mins to reach 0. but with the new battery it takes atleast 15 mins. also now in wifi network previously it gives 6.5 hours SOT. now I'm getting 8.5 Hrs SOT (average)... so far not tested in mobile data.
Balu332
Galaxy Note
Whats the total cost including tax bro...?
S_Kumar73
Galaxy Note
I replaced 4 days before the warranty expires. so free of cost..
sameergupta
Galaxy Note
Is battery replacement covered in warranty or you had some issues because of battery?
If they will replace free of cost then even I'm planning to get it replaced as my warranty will void this month
S_Kumar73
Galaxy Note
@sameergupta.. I told in my messages that I had a problem with my battery. they will replace only after checking the condition of the battery.
Balu332
Galaxy Note
Hi bro after battery change did you notice high heating issue while charging and...did They formatted your phone....?
