note 10 plus battery issues
(Topic created on: 07-30-2020 08:11 PM)
mittul1234
Galaxy Note
So my note 10 plus is having massive battery drain
It uses around 10 percent of the battery through the night and throughtout the day battery life is even worse i dont evem get 3 hrs screentime have turned off sync and all other advanced features
Please help
5 Comments
Ehsank
Galaxy Note
please do these settings to save more battery life
1. Connection>more connections settings> disable nearby device settings
2. Location>improve accuracy >disable
A. Wifi scanning
B. Bluetooth scanning .
3. Google >click on 3dot>usage and diagnostics >off this option
4. developer option >background limit>no background processes.
5. Long press on each app specially 3rd party and rarely used app>app info>
6. Device care>battery >select "optimised and adaptive power saving.
Ehsank
Galaxy Note
and after that go to developer option and disable this option
ZEALL
Galaxy Note
use maximum power saving it will limit the factionality of Phone but it will help with battery.
cs_member9
Galaxy Note
Dear Samsung Member,
To resolve your device battery drain issue please visit this link: https://www.samsung.com/in/support/mobile-devices/samsung-mobile-battery-drain-issue/
For further assistance, register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report/Ask questions).
MaverickSiD
Galaxy Note
facing similar issues since the start of purchase. (Note10plus, India) It is a waste buying a 512gb premium phone n getting no battery backup and screen-on time even when yhr battery b3ing so massive!!
