how to flash note 9 using smart switch..
(Topic created on: 05-24-2020 10:23 PM)
shoaib26
Galaxy Note
Anyone please help me in flashing my note 9 as due to lock down I can't go to service centre when I am clicking on emergency recovery mode in smart switch is asking for Android recovery code please help me anyone
9 Comments
Not applicable
Galaxy Note
once check in YouTube..because if we tell from here then you can't understand...so better go for practical visualization once
shoaib26
Galaxy Note
ok thanks bro
Palindrome
Galaxy Note
Emergency recovery mode in Smart Switch only works when your software update procedure is interrupted by any means, then the smart switch app will auto detect it and start the procedure of recovery on its own, u may need to enter into download mode of your device
shoaib26
Galaxy Note
ill try flashing my device... lets see
saltaf
Galaxy Note
Use ODIN to flash your device,
shoaib26
Galaxy Note
if i flash using odin...then will i be able to update my note 9 wai OTA updates in future...
Not applicable
Galaxy Note
yes you can use odin also no problem
saltaf
Galaxy Note
yes
shoaib26
Galaxy Note
thanks guys
