charging problem
(Topic created on: 07-05-2020 10:09 PM)
vkydhoni
Galaxy Note
My mote 9 doesn't support fast charging..It always shows cehck your charger connection like that..but I m using the adapter and cable which they provided only...please help me to sort out this prob
6 Comments
re1th
Galaxy Note
please check your cable first if any patches are there.... then remove cable and re attach the cable to adaptar... if works ok... if not.. then... check with any other fast charging cables....
vkydhoni
Galaxy Note
even if I use any other fast charging cable it still shows cable charging else check your charger connection like that
Galaxy Note
Hello vkydhoni,
Soemtimes due to removal of cable in incorrect manner causes this problem.
You can test it with other charger or can visit service centre in this case.
Thank you!
vkydhoni
Galaxy Note
yeah ok thank u
Dilli
Galaxy Note
Clean your phone charging port with an old tooth brush. Second try to get another cable or friends cable and try. It will tell you if your cable is damaged
vkydhoni
Galaxy Note
I bought a new cable worth ₹550..Nw it shows fast charging...
